Orbi WiFi 7 RBE973
Reply
Orbi WiFi 6 System (RBK842) AX5700
jdkorbi
Can I purchase the AX5700 directly from Netgear and use the 10% discount?
Message 1 of 7
Guru
Re: Orbi WiFi 6 System (RBK842) AX5700
IF the model is available at there store and you have the discount code, I presume so.
Message 2 of 7
jdkorbi
Netgear provides information at https://www.netgear.com/orbi/rbk842.aspx as if it's available, but the "Buy" link is not active.
Message 3 of 7
Guru
Possible the model isn't in stock is all.
Message 4 of 7
jdkorbi
At this point, a response from Netgear seems appropriate. Does the company monitor the community discussions?
Message 5 of 7
Guru
Infrequently. To get more immediate responce, I would contact NG support or a forum moderator.
@Blanca_O
Good Luck.
Message 6 of 7
Blanca_O
NETGEAR Moderator
Hi @jdkorbi
Thank you for your interest. We have no updates at the moment on availability. However, we recommend you check our online store periodically : https://www.netgear.com/orbi/rbk842.aspx
Blanca
Community Team
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 884 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
