Orbi WiFi 7 RBE973
Reply
Orbi ax4200 and LG OLED amazon and Netflix streaming issues. Buffering and dropping out of 4K
mirage_man
Guide
Just purchased an Orbi AX4200 Mesh system along with upgrading my internet service to 400mbps. I sat down to watch a show on Amazon Prime and I'm getting buffering and the video quality constantly dropping out of 4K into a really fuzzy picture. It is extremely distracting and very disappointing considering my old router never had this issue whatsoever. The device manager says my internet speeds are well above 400mbps and the signal strength is "Very Good" in the TV's location. In fact the router is literally on the other side of the wall not two feet away! Netflix also had trouble as well opening. Gave me an error at first.
I'm very frustrated after spending almost $500 on a router sytem that is no better than a $99 standalone. Considering streaming video is a top priority for a router. I'm hoping someone can shed some light on what is going on and if there's a fix. If not this will be going back ASAP.
And yes I know it would be better to hardwire the tv to the router but that's not an option.
Message 1 of 5
mirage_man
Guide
Re: Orbi ax4200 and LG OLED amazon and Netflix streaming issues. Buffering and dropping out of 4K
BTW FW version is V3.2.16.6_1.4.4
Message 2 of 5
Guru
Is the Orbi system operating in Router or AP mode?
What devices do you have connecrted to the system?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Message 3 of 5
mirage_man
Guide
Well not sure what happened but the issue seems to have resolved itself.
Message 4 of 5
Guru
Probably not Orbi related. Please mark your thread as solved.
Enjoy.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 862 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
