- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi range weak right outside front door
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBK753 (AX4200) - wouldn't show this as an option
Is very strong across entire 2,500 sq house - right outside our front door - very weak coverage. Please help! Router is in basement - but at front of house.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi range weak right outside front door
Please post about this over inthe Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Basements are not recommended places for wifi routers. Concrete and steel will inhibit wifi signal travel and coverage. 1st or main floor are best locations.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@shnanc wrote:RBK753 (AX4200) - wouldn't show this as an option
WiFi signal strength is reduced when they pass through denser materials. Basements tend to be horrible places to locate WiFi systems. The walls are almost always concrete. There is almost certainly a concrete/brick sidewalk leading up to the front door.
Perhaps it would be useful to make a rough diagram of the building and indicate where the Orbi router and satellite are placed and what building materials signals pass through. On the attached drawing, for example, a WiFi radio placed in location A will have a tough time passing through the concrete basement wall and sidewalk, whereas it might be capable of reaching a satellite at location C. WiFi at location B would probably "blast through" the front door just fine, whereas radio from location C would be passing through the entire house.
A lot depends on (a) where the ISP service enters the house, (b) where there are devices needing internet access (wired and WiFi), and (c) how difficult it is to place ethernet cables up from the basement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would throw a gigabit ethernet switch among the MR1100 and the Ubiquiti, simply so you could have additional LAN ports as you can see. If you get a gigabit ethernet switch with Power over Ethernet (PoE) and in case your Ubiquiti supports PoE, you may keep the more power outlet.
