- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi satellites not connecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Im ready to chuck it out the window. We had a disruption thru internet provider. When it came back up the Orbi would not work. My internet provider, Spectrum, has disruptions in service frequently here. If I have to go thru tthis evry time, its not worth the trouble to me to spend hours trying to reconnect the Mesh network. I have tried resetting everything and finally got the Orbi router to connect. But satellites will not. suggestions???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi satellites not connecting
You said Satellites.... can you tell us how many you have and how they are connected (wired or 5G RF backhaul)?
If wired, is there a switch between the RBR and RBS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
The RBS should auto sync to the RBR if there is a power loss. They should remain connected to the RBR if the RBR looses connection to the ISP modem...
@envirotecky wrote:Im ready to chuck it out the window. We had a disruption thru internet provider. When it came back up the Orbi would not work. My internet provider, Spectrum, has disruptions in service frequently here. If I have to go thru tthis evry time, its not worth the trouble to me to spend hours trying to reconnect the Mesh network. I have tried resetting everything and finally got the Orbi router to connect. But satellites will not. suggestions???
