- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
PS4 constant reset orbi rbk752
- Mark as New
- Bookmark
- Subscribe
- Permalink
However, I am experiencing an odd issue. My ps4 connection, which worked fine on my ac3000, constantly resets on my ax4200. However, it only resets when i turn off the ps4(or put it to sleep). When it boots up, it cant connect and i have to perform the setup again. No issues with other devices. The ps4 sits about 3ft away from the router and has a great signal(yes, i could wire it, but my wife HATES wires, so itd be easier to get rid of the ps4)
Whats happening is that the ps4 finds the connection, but refuses to pull the data from the dhcp. Is there anyway around this other than maybe using a manual setup? (I will try this later tonight to see if it works)
And anyone else have any issues with their ps4?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last FW update.
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Set up a IP address reservation for the PS console on the RBR. Under Advanced Tab/LanSetup
Wired connection is preferred for gaming.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: PS4 constant reset orbi rbk752
1. I have not done a settings reset since the firmware update. I have reset the router a few times.
2. I looked at the rts/cts and they were set to 64. So I changed them to 2347.
3. I created an ip reservation.
It seems the big issue was the rts/cts as once i changed those, not only did my ps4 actually renew its network as it its supposed to, but the Dl speed increased by 300%.
Also, just a note, I agree wired is preferred, but i dont play much pvp, just need it for dl games and connecting to psn. My xbox is wired as i play pvp games on that.
Thanks for the help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad that worked.
Ya, I play PvP and like to have the best performance on xbox.
Enjoy.
