Orbi WiFi 7 RBE973
Reply
Questions about wired backhaul
nk1975
Hello
I recently bought the Orbi AX6000 rbk852 2 pack
and am pretty happy with it.
However I still get a few weak signals around my house. I have the router upstairs
and the satilite in the basement directly wired into the gaming system for the kids.
I am considering buying another satelite so I can set up the wired backhaul.
Will that give me any additional benifit?
Thanks!
Message 1 of 8
Accepted Solutions
Guru
Re: Questions about wired backhaul
Message 4 of 8
All Replies
Guru
Sometimes wired vs wirelss is more stable than wireless or if you want a RBS out a fare distance from the RBR, the RBS won't connect wirelessly so wired RBS can be setup for this configuration. The only draw back is that the back haul speed is limited to 1000Mbos vs 2400Mbps that the Orbi AX provides wirelessly. 1000Mpbs wired speeds are still good and have good performances.
Message 2 of 8
nk1975
Ok, thanks!
So I can still have my satelite in the basement wired into the gaming system,
and buy the 3rd satalite and do the wired backhaul into the main router?
That's what I want to do.
I am fine with the speeds, as the wireless speeds on 5g and kinda all over the place.
Thanks!
Message 3 of 8
Guru
Yes.
Message 4 of 8
nk1975
Thanks for the help.
Now I need to find a place that sells the satalite.
Message 5 of 8
Guru
Good Luck.
Message 6 of 8
nakenergy
Guide
RBK852
if wireless backhaul is 2400 Mbs while wired is 1000 mbs, would wireless back haul be better than wired?
Message 7 of 8
gb777
Apprentice
The 2400 is a theoretical maximum.  1000 Mbps over wired is guaranteed with CAT 5e wiring, aka Gigabit Ethernet.
It's unlikely that you beat that over wireless; see this 2017 article: https://www.cnet.com/how-to/your-router-isnt-as-fast-as-you-think-it-is-heres-why/
But if you do, I'd like to know!
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2825 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
