ihsteven
Jun 02, 2020Guide
RBK753 vs RBK753s
Does anyone know what the difference is between the rbk753 and the rbk753s ?
https://www.netgear.com/orbi/rbk753s.aspx (S model)
https://www.netgear.com/orbi/rbk753.aspx (regular one)
-Steven
RBK753s : 1 year Armor subscription included
RBK753: Armor free trial period only
"s" probably means "subscription".
- kildareLuminary
S=Security.
Nothing different HW wise.
Orbi AC has a same thing.
- ihstevenGuide
You guys are awesome. Thanks for the fast updates!
-Steven
- coldkeyesAspirant
Hello; I had a question about Port Triggering/Port Forwarding
is there a limit on how many you can do on the RBK573 and RBK573s?
I am looking to be able to play games on xbox live, psn, steam, origin, uplay and make sure to get reliable twitch streaming connection
Can someone confirm this for me please?
I am looking to buy a high end powerful router for my network
I have ATT Uverse and I have 120mb down and 20mb upload speeds
I hate the modem gateway unit so much; I can't stand it having no port triggering/port forwarding options
So I want to know before I purchase this either the RBK753 or RBK753s- BlueSurfAspirant
I bought the RBK753S about 3 weeks ago at Costco. It has the router and two satelites. I paid on sale in the store $449.00, paid tax and bought from Netgear additional two years total coverage and Technical support. (All in total was $570.00) I turned off the Armor Protection. I found it blocking websites I always use, and there should be a popup asking me what I want. Nope no pop up. I have Norton Security suite from Comcast. I also have Malwarebytes Corporate. If they FIX Armor I'll reconsider using it too. My RBK753S is OUTSTANDING!
