- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK753S - Much slower wifi speeds after AUTO firmware upgrade to 3.2.18.1! 3.2.17.x was MUCH faster
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Quick update - Since I am / was experiencing the low speeds noted above (330 - 350 Mbps), I just disconnected and reconnected my Netgear A7000 wifi adapater from the network in Win 10 (did NOT unplug it).
After reconnecting to the network, speeds improved to 430 Mbps on first run after reconnecting, then 471 Mbps, 476 Mbps, 468 Mbps, one slower one of 451.7 Mbps but much better than before the disconnect/reconnect, and then 470 Mbps.
Will monitor stabilty after a few hours and also after a full day or two / after restarts / hibernates/ shutdowns etc.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK753S - Much slower wifi speeds after AUTO firmware upgrade to 3.2.18.1! 3.2.17.x was MUCH fa
Did you power OFF the RBR and RBS for 30 seconds after the update or factory reset and setup from scratch?
Something to contact NG support about and let them know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Did you power OFF the RBR and RBS for 30 seconds after the update or factory reset and setup from scratch?
Thanks.
Unfortunately, I could not power off and restart the router / satellites yet since that takes too long given I was working and on a call and wife is on a call now. A quick adapter disconnect / reconnect right after my call was less intrusive.
I can try when we are both not actively on calls / responding to emails etc.
In the meantime, will run some more tests...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Very happy to report that for now, wireless speeds have stabilized, ever since the 10:24 AM test I referred to above. Also no wifi connection issues (tested using my Netgear A7000 USB wifi adapter).
The true test, based on my prior experience, will be seeing how it holds up, in terms of continued stability, over the next day or so...
So long as speeds hold up and I have no disconnects the next day or two, I will consider this 'solved'.
My plan is 400/10, but as you can see, I am getting almost 480 Mbps wirelessly.
Date/time......Ping.Download. Upload.
04/29/2021 9:57 PM | 11 | 475.84 | 11.97 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
3:23 PM | 12 | 478.38 | 11.77 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
12:45 PM | 12 | 445.95 | 11.72 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
10:43 AM | 13 | 466.39 | 11.91 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
10:30 AM | 12 | 469.99 | 11.72 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
10:29 AM | 12 | 451.69 | 11.95 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
10:28 AM | 12 | 468.44 | 11.94 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
10:25 AM | 12 | 476.31 | 11.94 | < 50 | Matawan, NJ Vultr | XFINITY | |
The 10:24 AM test got 471.09 Mbps did but not copied / pasted...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ran a few tests myself on my 8 series with v1 loaded: Armor/TM disabled. DST Enabled. CTS set to 64(default)
Mac Book wireless connected to RBR: 866Mbs Connection Rate
Mac Book Pro Connected near the RBR: 1300Mpbs Connection rate which is max rate for Mac Book Pro 2018
Mac Book Pro wire connected to a NG R7800 router in wireless bridge mode connected at 1733Mbps to RBR:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Furry - Nice results (above)!
I ran my FIRST Speedtest of the day and immediately got 473.42 Mbps out of ~480 Mbps provisioned, so it looks like I may stick with 3.2.18.1 since it appears to be working well! 🙂
Will wait till Satruday evening or Sunday morning to consider this solved to be safe (i.e. I want to ensure stability over several days).
I need to check and monitor my TiVO MoCA connection though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I may go back and re-test with CTS set to 2347 and see how that does.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:I may go back and re-test with CTS set to 2347 and see how that does.
No noticeable adverse effects here with CTS set to 2347, but I have not extensively tested concurrent intensive connections (e.g. downloads, concurrent streaming etc.), but I would have likely noticed by now anyway given typical activity.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds good. Ya, not sure why NG went with 64 instead of 2347 which is on there older systems. Seems to be a mixed bag of it works form some and not others. At least we can change that value.
No noticeable adverse effects here with CTS set to 2347, but I have not extensively tested concurrent connections but would have likely noticed by now..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Correct. However, since 3.2.18.1 is working great, I am going to stick with it and glad to have the latest security fixes again. However, I am going to block connections to the update server, so it can no longer update automatically.
It has been written in many places that once you update manually once, the Orbi supposedly no longer updates automatically. However that is not the case anymore / not the case with the RBK753S.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sure. I prefer to play it safe with security though 🙂
Interesting that you have not seen any auto updates in so long; which model do you have?
I had also noticed the reference to the ability to turn off auto updates (jn some old threads); they must have removed that option again (assuming it did get implemented at the time), or perhaps it only applied to a specific model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks...a couple of thoughts....IMHO the whole thing about security fixes is over blown. I believe in most cases it's just NG padding the update to get people anxious to try it. As far as auto updates, I personally haven't seen one in maybe 2 years and for me it's not due to manual updates for I don't do those. Some say you turn off auto updates, if you can, I've never seen how.
Mine auto updated the other night. It was about 2am Eastern and my wife woke me up asking why the satellite in the room was blinking blue. I looked at my tablet and saw it was down, and realized what might be happening. As soon as it was back up, I looked and lo and behold, it was the .18 firmware (I know for a fact that it was on the .17).
Another reason why I'm dumping Netgear/Orbi on my next upgrade and going back to Asus.
