Orbi WiFi 7 RBE973
Reply
RBK753S and CM1100
MN_Dave
RBK753S and CM1100
Hello all. I just bought a RBK753S-100NAS and I am having issues with connecting it to my CM1100 cable modem. I have no issues with connecting my old DLink WiFi Router to the cable modem, but whenever I connect the Orbi router the modem shows two orange lights on the Ethernet LEDs and no other LED lights are lit, I have no internet connection either. I finally gave up and reverted to my old setup with the DLink router but obviously I’d prefer to get the new set up working. Any help or advice?
Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem—DOCSIS 3.1
Message 1 of 4
Accepted Solutions
Guru
Re: RBK753S and CM1100
Power OFF the modem for 1 minute then back on, either reboot the RBR or factory reset the RBR at the same time and walk thru the setup wizard.
Message 2 of 4
All Replies
Guru
Message 2 of 4
MN_Dave
Thank you. I had tried to do that a couple of times. I must have just been to impatient. This time it work. Thank you!
Message 3 of 4
Guru
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1112 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
