Orbi WiFi 7 RBE973
Reply
RBK850 Guest Network Port Forwarding
magoldsm1
My goal is to provide my students access to a machine in my home without allowing them onto my general home network.  What I was thinking was this:
  • Isolate the machine for student use on the guest network.
  • Enable port forwarding for desired ports to that machine.
This doesn't seem to be possible (at least with my current firmware.  Due to the NAT loopback issue, I am still running V3.2.16.1_1.4.4).  While the port forwarding web page allows me to specify the 192.168.2.x network, when I Apply, it is rejected.
Does anyone have any suggestions?  I looked at VLAN in the manual, but the entire discussion revolves around bypassing NAT, which is not what I'm trying to do.
Thanks,
Michael
Message 1 of 3
Guru
Re: RBK850 Guest Network Port Forwarding
Guest Network already gets a assigned the .2.### address. Guest Network is already on the WAN side of the router thus there is no need for port forward Guest Network which isn't supported.
Message 2 of 3
magoldsm1
I mis-stated my question.  I'd like to give the students *remote* access to the machine in my home, while maintaining isolation of that machine from the rest of my home network.
Thanks,
Michael
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 720 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
