Orbi WiFi 7 RBE973
Reply
RBK852 satellite wireless backhaul
kvtong93
Hello Everyone, I have a question, if I add one more satellite to orbi system,how can I let two satellite do the wireless backhaul to extend the distance of my wifi system, thanks
Message 1 of 4
kvtong93
Re: RBK852 satellite wireless backhaul
anyone? I don't know if sync rbk8 series satellite with satellite is possible.
Message 2 of 4
Guru
You can add another RBS. ALL RBS perform wired or wireless backhaul and help extend the wifi signal that comes from the RBR.
Message 3 of 4
Chuck_M
Mentor
You are not limited to one wired satellite.... on my setup I have a switch "downstream" of the RBR850....  I have two satellites (RBS5's) connected via CAT5 back to the switch.    My RBS850 is wireless back to the RBR850.
Summary:  run additional CAT 5 or 6 to the location you want to put another satellite and it will work fine.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 536 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
