- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK852 with RBS50?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I currently have an RBK50 system with two satellites. If I bought an RBK852 system, would I be able to use my two current satellites with it? Obviously they wouldn't be able to throw the 802.11ax signal around, but could they be used to just increase the network coverage, WITHOUT dragging my entire network down to 802.11ac speeds?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can LAN wire connect RBS50s to the RBR850 only. RBS50s are not currently wirelessly backhaul compatible. NG is supposed to make them wirelessly compatible. No time frame though on when that will happen. So you can use RBS50s like wired APs only at time time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
