Reply
RBR 850 Router - add RBS 750 satellite
jneusch64
I saw a previous post about adding an RBS 750 satellite to an 850 system, but the OP was using wired backhaul.  I am in a similar situation where I need to add an additional satellite to my 852 system, but I will be running it with wireless backhaul.  Will I lose anything by purchasing a 750 satellite?  It's $150 cheaper, but not worth it if it doesn't get the job done.
Thanks!
Message 1 of 4
Accepted Solutions
Guru
Re: RBR 850 Router - add RBS 750 satellite
Only connection rates between the connect devcies and the RBS.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 4 of 4
All Replies
Guru
The wireless backhaul is the same, however front haul is just a bit slower in rate on the 7 series than the 8 series. Otherwise the RBS will work fine. Look at the spec sheets for each series to see the differences.
Message 2 of 4
jneusch64
Thanks for the reply.  I saw that the 750 is a bit slower, but will it negatively impact the overall wireless speed of the 850 satellite and the router, or only the wireless speed of itself?  I don't want to negatively impact the overall system.  Glad to hear that the wireless backhaul won't be affected.
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 120 views
  • 1 kudo
  • 2 in conversation
Announcements
