- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850 Double NAT Type error after 2 days
- Mark as New
- Bookmark
- Subscribe
- Permalink
Recently purchased the Wifi 6 Orbi mesh wifi system. After 2 days, I'm no longer able to sign into routerlogin no matter how many times I try and change the password it still won't let me sign in. I also get "Double NAT" error from the Xbox One and if I play games on the PC (only microsoft/xbox games that are on PC as well) I get randomly dropped out from the game every 15 minutes or so. This is extremely frustrating. Any and all help is appreciated!
Both the xbox and PC are connected the the RBS850 sattelite
Orbi RBR850 Router
Orbi RBS850 Sattelite
Arris Surfboard Modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 Double NAT Type error after 2 days
Seen this before since AX came out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ClutchRaid wrote:Recently purchased the Wifi 6 Orbi mesh wifi system. After 2 days, I'm no longer able to sign into routerlogin no matter how many times I try and change the password it still won't let me sign in. I also get "Double NAT" error from the Xbox One and if I play games on the PC (only microsoft/xbox games that are on PC as well) I get randomly dropped out from the game every 15 minutes or so. This is extremely frustrating. Any and all help is appreciated!
Orbi RBR850 Router
I'm having this same issue and came here for this! When I play on Xbox games I'm constantly dropping out of games and when I was wired to a satellite on my RBK850 I was getting a double NAT issue. They need to fix this ASAP as I work from home, it seems to be with the latest firmware I'm assuming.
I'm running the RBK853 (1 router, 2 satellites), Docsis 3.1 Netgear modem w/ gigabit connection
Firmware: V3.2.10.11_1.2.12
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RBR850 is currently on V3.2.10.11.
The RBS850 is currently on V3.2.10.11.
The Mfr of the modem is Arris.
The model # is SB6183.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also power OFF the Arris modem for 30 seconds then back on.
Be sure to clear out any PC network caches or power OFF the PC fully, including the power switch in back if there is one. Then back on after 30 seconds. If your using a game console like xbox, hold the front power button until the console shuts off. After the modem and RBR are back online, power ON the xbox and check NAT status under Settings/Networking. Port used should be 3074 and say OPEN.
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
If this still fails, Please contact the forum moderator if your having problems with the lastest version of FW:
https://community.netgear.com/t5/Orbi-AX/ORBI-RBR850-frequent-disconnects-to-WoW-server/m-p/1871943/...
Thank you.
@ClutchRaid wrote:The RBR850 is currently on V3.2.10.11.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have not done a factory reset, but I'm also unable to sign in to routerlogin. It keeps making me reset my password then tells me the new password is incorrect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to clear your browser cache first, exit the broser then relaunch. Try a different browser as well. I use Opera.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I've done a factory reset of the Orbi system and still get the "Double NAT" error. I also rebooted the arris modem several times now and have rebooted the sattelite and router several times now. I'm able to access router login now after doing the factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you connect your PC and or xbox directly to the RBR?
Be sure to hard power OFF the xbox by pressing the front power button and hold it until the xbox shuts off. Then connect to the RBR then power ON. Should have OPEN NAT here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't connect them to the RBR based off of where the devices sit and are set up at and where the RBR is. I could turn the satellite off and then try the xbox that way though. But what could I do to try and fix this Double NAT issue? It has to lie with the satellite I'm sure. It gives me Double NAT and strict NAT type on the xbox and spotty connection on the PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, turn OFF the RBS. Configure the xbox to ensure it will connects wirelessly to the RBR. Once this is done. Hard power OFF the xbox by pressing the front power button and hold it until the xbox shuts off. Reboot both ISP Modem and RBR and let them come to ready. Once they are up, power ON the xbox. Check NAT status here. Should have OPEN NAT here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is Open when the satellite is turned off, but connection isn't amazing due to distance from the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, Is the FW on the RBS the same as the RBR? Just checking.
Seems like the RBS is causing problems.
Have you factory reset the RBS alone, then re-added it to the RBR?
What is the current CTS and RTS values on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
The FW is the same.
I have not tried resetting just the satellite by itself.
Here is a link to a SS of that settings page:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, lets reset the RBS. Press the reset button in back for 15 seconds the release. I would bring the RBS to where the RBR is, say 10 feet. Reset then setup the RBS and re-sync it to the RBR. Once it's synced and added and it appears on the RBRs web page. Turn it off and put it back in the remote location.
I remember seeing this with mine however I haven't tested mine for a while since having other problems. I'll check with mine again this weekend.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried that and I still receive the Double NAT error after it.
Edit: After 15 min went by, tried the NAT test again on xbox and have gotten OPEN now twice. Don't know if it will stay open but it's a start
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully between the RBS and xbox, you should be good. Keep an eye on it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ClutchRaid Maybe you can offer up some assistance here?
https://community.netgear.com/t5/Orbi-AX/Double-NAT-Strict-NAT/m-p/1873686#M1969
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am actually receiving the same issue again now so I'm unsure if I'd be of much help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even with the RBS turned OFF?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you disable uPnP on the RBR and put the xbox IP address into the DMZ on the RBR.
You might try this on the RBR:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did not try putting the xbox in the DMZ, but downgrading the firmware and blocking future updates has worked for me for sure! No problems now on the old firmware.
