- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850 Frequent Disconnects Starting March 9th AM EST
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh system, and my NEST devices and my work laptop seem to be the only devices being dropped consistently, at least that i can verify right now. I have two Xbox's running at the same time for streaming and gaming, my sons PC does not drop, phones don't drop, etc. But since yesterday, every 10 mins or so my work laptop and Nest devcies drop from the network, then reconnect after about 2-3 mins. I have had the Orbi AX system for about 3 weeks (coming from the AC version) and my performance across my network has been stellar - until yesterday morning at 6AM EST.
I've tried soft rebooting the system, i've power cycled everything, and the issue persists. I have not tried downgrading firmware.
My Firmware version is 3.2.10.11
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 Frequent Disconnects Starting March 9th AM EST
What happens if you disable AX mode on the RBR?
Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Under Advanced Tab/Advanced Settings/Wireless Settings. Save settings and reboot the router and satellite(s).
What generation is your NEST thermostats? I have 1 1st gen and 1 3rd gen. I did notice that my 3rd gen disconnected the other day. I had to have it reconnect...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having a similar issue. It looks like there was a firmware update (v3.2.10.11) that started these issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@cruisencode wrote:I'm having a similar issue. It looks like there was a firmware update (v3.2.10.11) that started these issues.
Besides my Google Nest Hub Max, my Ooma device keeps disconnecting as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just downgraded my FW to 3.2.9.2 so we'll see what happens...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MeGrimlock wrote:I just downgraded my FW to 3.2.9.2 so we'll see what happens...
I've read in the other threads that this doesn't help. Keep me posted. I was planning to troubleshoot this more when I get home from work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No problem. I also opened a support ticket with NG.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for following up with NG support.
Hope this will get solved soon.
@cruisencode wrote:No problem. I also opened a support ticket with NG.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Downgrading the FW did not work. Still having the disconnects on the same devices on V3.2.9.2
I don't know I've seen an issue like this where downgrading FW didn't at least help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's very strange. I want to try downgrading, but I also don't want to waste my time. I suppose I'll give it a shot and see what happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you disable AX mode?
And after downgrading did you factory reset the RBR and setup from scratch?
I think this worked for this user.
Ensure WMM is enabled. Under Advanced Tab/Advanced Settings/Wireless Settings
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
@MeGrimlock wrote:
Downgrading the FW did not work. Still having the disconnects on the same devices on V3.2.9.2I don't know I've seen an issue like this where downgrading FW didn't at least help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Orbi AX Community,
May you check your CTS/RTS threshold under WiFi settings. If it's set to 64, may you try setting it to 2347 and update the thread with your results.
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for pointing this out. I've always remembered mine being set to 2347, but I did just check and it was set to 64. i set it back to 2347 so I will see if that helps. Would the latest FW have set it to 64?
@Christian_R wrote:Hello Orbi AX Community,
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe so. I went in yesterday and set Short Preamble instead of Long as I hoped to stop my NEST contoller from disconnecting upon recommendation from another user. I remembered seeing this and didn't think anything about it since my system has been working mostly.
Hope this might help the disconnects if this is the case. Let s know what you see after changing it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My network has been having all sorts of very weird performance and connectivity issues recently. It looks like this firmware update may be the culprit. I have also been having the Nest camera disconnection problem. I also noticed that my Pixel 2 XL Android phone had momentary WiFi interruptions early this morning while I was in bed. I have to say I'm not very impressed with Netgear's latest and greatest so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks,
Christian
It was set to 64. Changed to 2347 and still disconnecting. Wired AND wireless devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if AX mode is disabled. Re-enable after trying this.
You may need to downgrade FW.
@d1mmy wrote:My network has been having all sorts of very weird performance and connectivity issues recently. It looks like this firmware update may be the culprit. I have also been having the Nest camera disconnection problem. I also noticed that my Pixel 2 XL Android phone had momentary WiFi interruptions early this morning while I was in bed. I have to say I'm not very impressed with Netgear's latest and greatest so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still Disconnecting same devices with 2347 CTS/RTS
@MeGrimlock wrote:Thanks for pointing this out. I've always remembered mine being set to 2347, but I did just check and it was set to 64. i set it back to 2347 so I will see if that helps. Would the latest FW have set it to 64?
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm also having issues on my wired connection with intermittent outages. See my "upload" on my most recent speed test. This was done on a desktop wired via Ethernet directly to my RBR850: https://imgur.com/I2bW57Mhttps://imgur.com/I2bW57M I'm not sure whether this is my internet connection, router(s), or both. I'm going to look into rolling back the firmware when I get a chance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would revert back to v3.2.9.2. Manually load the RBR then factory reset the RBR and setup from scratch. Not sure if the RBS needs to be downgraded as well. Up to you to try. Seem like the RBR is effected by the recent FW rather then the RBS is.
@MeGrimlock wrote:Still Disconnecting same devices with 2347 CTS/RTS
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you factory reset the RBR and power OFF the ISP modem for 3 seconds then back on then walk thru the setup wizard on the RBR?
@d1mmy wrote:I'm also having issues on my wired connection with intermittent outages. See my "upload" on my most recent speed test. This was done on a desktop wired via Ethernet directly to my RBR850: https://imgur.com/I2bW57Mhttps://imgur.com/I2bW57M I'm not sure whether this is my internet connection, router(s), or both. I'm going to look into rolling back the firmware when I get a chance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Spectrum (formerly TWC) internet in the LA area. I'm connected through an Arris SB8200. The only thing I've done today so far has been to reboot the RBR850. Unfortunately, having my internet working consistently has become more important this week as my current client has essentially closed their offices and asked everyone to work from home indefinitely. I'll update this thread once I've been able to downgrade and reset my satellite and router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, just making sure your modem is stand alone. Your good.
Let us know about the downgrade. Please factory reset the RBR and setup from scratch.
Ensure that the CTS values are at 2347. I think they should be.
@d1mmy wrote:I have Spectrum (formerly TWC) internet in the LA area. I'm connected through an Arris SB8200. The only thing I've done today so far has been to reboot the RBR850. Unfortunately, having my internet working consistently has become more important this week as my current client has essentially closed their offices and asked everyone to work from home indefinitely. I'll update this thread once I've been able to downgrade and reset my satellite and router.
