- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850 Frequent Disconnects Starting March 9th AM EST
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 Frequent Disconnects Starting March 9th AM EST
Send you a PM.
@d1mmy wrote:I have Spectrum (formerly TWC) internet in the LA area. I'm connected through an Arris SB8200. The only thing I've done today so far has been to reboot the RBR850. Unfortunately, having my internet working consistently has become more important this week as my current client has essentially closed their offices and asked everyone to work from home indefinitely. I'll update this thread once I've been able to downgrade and reset my satellite and router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had already downgraded the FW on both router and satellite, so now i've factory reset the system and my FW is still on 3.2.9.2
All other settings are where they should be - now we wait
@FURRYe38 wrote:I would revert back to v3.2.9.2. Manually load the RBR then factory reset the RBR and setup from scratch. Not sure if the RBS needs to be downgraded as well. Up to you to try. Seem like the RBR is effected by the recent FW rather then the RBS is.
@MeGrimlock wrote:Still Disconnecting same devices with 2347 CTS/RTS
@MeGrimlock wrote:Thanks for pointing this out. I've always remembered mine being set to 2347, but I did just check and it was set to 64. i set it back to 2347 so I will see if that helps. Would the latest FW have set it to 64?
@Christian_R wrote:Hello Orbi AX Community,
May you check your CTS/RTS threshold under WiFi settings. If it's set to 64, may you try setting it to 2347 and update the thread with your results.
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Your CTS/RTS values should be 2347 by default.
Let us know how it goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even after the Factory Reset and running older firmware, same devices are still disconnecting at the same rate. I'm at a loss now. Need to wait for NG to update us on this issue.
@FURRYe38 wrote:Ok. Your CTS/RTS values should be 2347 by default.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are your CTS/RTS values at 2347 on the RBR?
Have you rebooted or power cycled your wifi connected devices? I would do this.
Ensure WMM is enabled. Under Advanced Tab/Advanced Settings/Wireless Settings
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Are your CTS/RTS values at 2347 on the RBR?
I'm not sure any of this matters. I'm having issues with wired devices as well. Why would any of these wireless settings impact my wired devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
They won't. Was to see about wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For those still experiencing issues, please send me a private message with the following:
- Contact Info
- Serial Number
- Troubleshooting steps performed
- Network topology
Thank you,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll PM this info after work.
Anyway, I put my old Asus router back and set my Orbi to AP last night. No more disconnects and everything is stable again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
PM sent
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been commenting on one of the other threads: https://community.netgear.com/t5/Orbi-AX/Orbi-Firmware-v3-2-10-11-seen-on-your-RBRs-FW-update-check-...
I PM'd Christian with details and my NG support case # as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you can, help collect WAN/LAN and debug logs and send them to Christian and include them with your support ticket. Might be helpful.
Thanks for your help. Hope NG will get this fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Debug logs have been attached to my NG support case. I will send those logs to Christian as well momentarily (once I figure out how).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, if they are attached in the support ticket, Christian should have access.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just sent you a PM Christian, thanks
- Contact Info
- Serial Number
- Network topology
Thank you,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
My wired desktop is also having connection problems now after the latest firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only 1 desktop wired or do others as well?
What kind of problems are you seeing?
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
@DoctorA wrote:My wired desktop is also having connection problems now after the latest firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same problems as everyone else here, tried all the troubleshooting and still disconnects. This couldn't have happened at a worse time since my company went to a work from home model and my VPN drops every 5-10 minutes!
Please get this fixed ASAP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Poolrad wrote:I'm having the same problems as everyone else here, tried all the troubleshooting and still disconnects. This couldn't have happened at a worse time since my company went to a work from home model and my VPN drops every 5-10 minutes!
Agreed! My wife works from home, but she doesn't need a VPN. However, our Ooma Telo keeps dropping her phone calls because of this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please contact @Christian_R
He's now working with those of you effected by this FW update.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried putting your Ooma device into the RBRs DMZ by chance to see if this help any?
@cruisencode wrote:Agreed! My wife works from home, but she doesn't need a VPN. However, our Ooma Telo keeps dropping her phone calls because of this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just put the Ooma's IP into the "Default DMZ Server" field under the WAN Setup. We'll see what happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep did that, also sent Christian a PM with my info and offered to email him my logs that I captured while debugging this while it's been happening. Waiting on a response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
While on the phone with a level 2 NG tech yesterday we reverted my firmware back to 3.1.5.23. We initially had just set the RBR850 to AP mode, but out of curiosity I went ahead and put it back to full router mode. That has completely eliminated dropped connections and I'm not experiencing any issues.
What ever was broken in 3.2.11 seems to have also been broken in 3.2.9.2. I wasn't keeping up with the firmware version numbers that my RBR850 had installed prior to having 3.2.11 but it seems it was not 3.2.9.2.
I hope this helps!
