- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850 with RBS850 Satellites (4)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I have RBR850 and (4) RBS850 .. 6500 Sq ft house
ATT -1 Gig fiber into the house
I am not using the router provided by ATT, I have created a bridge and use the Orbi as router.
The 1 Gig into the house and Orbi Router is fine, However I am lucky if I get 100MB within the separate rooms of the house on wifi
We also get intermitment outages / very slow speed (even in room where the satellite are in front of all devices)
Any help would be appreciated. I have escalated to level 1 and its a finger pointing exercise vs. fixing the issue
Thanks
Rimasiddi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 with RBS850 Satellites (4)
Make sure the ISP modems wifi is fully disabled if the modem has wifi.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
the fimrware is 3.2.18.1
I have the Large house layout per the diagram.. The router is on the second floor ( since that where my home wiring is )
the satellites are in 3 corners of the house..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Didn't see any diagram attached to your post...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
its a 2 story home (8000 Sq ft )
2 nd story
top right closets to home entrance - router / att modem
top right furthest from home entrance - back of house - (Sat 1)
Top left furthest from Router- back of the house ( Sat 2 )
sat 1 and sat 2 ( extreme right / left back side of the house)
first floor
back right Sat 3
front left Sat 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
A layout or drawing of where the system is placed would be more helpful so we can see where there located with in the home.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So by the looks you have RBS#4 right under the RBR...This would not be good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
it is.. I can change/ move that to the middle of hthe house as well
thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. Around 30 feet is needed in between the RBR and any RBS and from RBS to RBS as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok will try that.. Any suggesstions for getting speed throughput .. I have a 1 GIG fiber line, and at this point the best room gets 300MB.. all the others get 100 MB
