Reply
Highlighted
Tutor
RBS850 Phantom MAC address appearing/disappearing from LANwith same IP as Satellite
I have RBK853 (1 x RBR850 & 2 x RBS850) + 1 x additional RBS850 satellite.  All satellites are Cat 6 cabled direct to RBR850 router, All devices on same firmware version  v3.2.16.6 and have been factory reset, and mesh resync'd to router.  Guest Network is disabled and RBR850 is in Access Point Mode.  All appears to be working ok apart from the additional satellite which occasionally drops out out the mesh network and then immediately reconnects and resyncs.
It appears that the route cause for the additional satellite to eventually disconnect/reconnect to the mesh network via wired backhaul, is due to a phantom MAC Address which is constantly appearing/disappearing on the LAN.  The actual DHCP IP Bind address for the additional satellite is 192.168.1.6 which is bound to MAC 10xxxxxxxxDA, whereas the phantom MAC address is 12xxxxxxxxDD (xxxxxxxx denoting identical details) which also appears on the network with the same IP address of the satellite 192.168.1.6.  My manage switch the detects a duplicate IP address on the network and starts to alert.
I have tried to setup an DHCP IP Bind for the 12xxxxxxxxDD MAC, but it never makes a DHCP request and always assumes 192.168.1.6!
I have factory reset all devices and started over many times, but the additional satellite to the original RBK853 kit, always ends up with the same trait.
Any help with this would be much appreciated.
Message 1 of 15
Highlighted
Guru
Re: RBS850 Phantom MAC address appearing/disappearing from LANwith same IP as Satellite
What is the mfr and model# of the main host router the RBR is connected to?
What is the Mfr and model# of the ethernet switch in the configuration?
Where is the swtich connected? Between the RBR and RBS?
What browser are you using?
Please provide a screen capture of that your seeing. Use the Choose File button to attach the capture file.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK50 v2.7.0.70(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 15
Highlighted
Tutor
Draytek Vigor 3910 Router WAN port is connected to a Virgin Media Hub 4 (in Modem Mode) - Gig1 Service
Draytek Vigor 3910 Router WAN failover is connected to a Netgear 6400 AC1600 VDSL/ADSL Modem (in Modem Mode), BT 64Gb service
Draytek Vigor 3910 Router WAN failover load balancing, connected to USB LTE Modem, Virgin Mobile 4G Unlimited Data
RBR850 iNet port is connected directly via Cat 6e Cable to a 2.5Gb LAN port on Draytek Vigor 3910 Router
Draytek Vigor 3910 Router - Latest Firmware
Draytek Vigor G2280x Managed Switch - Latest Firware
The RBS's are direct cabled via Cat 6 cables to the RBR, all 1Gb links.
The RBR is connected via its iNet Port directly to the Daytek Vigor 3910 via 1m  2.5Gb LAN link
The G2280x switch is connected directly to the Draytek Vigor 3910 via 1m 10Gb SFP+ cable
Various browsers ... MS Edge, MS  IE, FireFox or Chrome ... all latest versions vailable
Message 3 of 15
Highlighted
Tutor
Message 4 of 15
Highlighted
Tutor
Message 5 of 15
Highlighted
Tutor
These are when the phantom MAC address has gone online/offline and has the IP address of 192.168.1.6. The actual satellite assigned 192.168.1.6 has not dropped our of the mesh network so far today!
Message 6 of 15
Highlighted
Guru
Have you set up IP address reservations for the RBR and RBS on your host router? Something to try and see if this changes any behaviors.
I presume you are using Dynamic AP mode vs Static IP addressed AP mode on the RBR?
Message 7 of 15
Highlighted
Tutor
192.168.0.1 - Virgin Media Hub 4 in Modem Mode
All network devices have reserved IP addresses via DHCP IP Bind controlled by Draytek Vigor 3910
192.168.1.1 - Draytek Vigor 3910
192.168.1.2 - Draytek G2280x Managed Switch
192.168.1.3 - RBR
192.168.1.4 - RBS Satellite-1 (Included in RBK853 - no issues)
192.168.1.5 - RBS Satellite-2 (Included in RBK853 - no issues)
192.168.1.6 - RBS Satellite-3 (additional satellite - duplicate IP address due to mac 12xxxxxxxxDD)
I have tried assigning IP addresses directly via Orbi's Admin Pages, but additional RBS still has the same trait.
I have also created a DHCP entry for 12xxxxxxxxDD, but it always has the same IP address as the Satellite itself.
I note from the RBS Satellite-3 'Cpture Debug Logs' that the 12xxxxxxxxDD mac address is associated with its eth3.
I also note that during the period the capture was runninig there was no entries in the pcap log for the 12xxxxxxxxDD mac address, but that is what I would have expected, as I didn't recieve any duplicate network IP address alerts for the same time period.
FYI, I have now plugged the ethernet cable between the RBS Satellite-3 and the RBR into Port 1 of the Satellite and power cycled to see if that makes any diffence.  I wouldn't have thought so, but would probably expect the issue to transfer to mac address 12xxxxxxxxDA!
Message 8 of 15
Highlighted
Guru
When setting up IP address reservations, you need to set the reservation ON the main host router, not the RBR when in AP Mode.
Message 9 of 15
Highlighted
Tutor
The reservations are set by the Draytek Vigor 3910 Router and not on the RBR/RBS's
Message 10 of 15
Highlighted
Guru
What happens if you turn OFF the other RBS leaving this one with the Phantom MAC on, does the problem still appear?
Try swapping this one RBS with one of the other RBS in it's placement and connection to see if the problem follows. If so, I would make contact with NG support about this.
Message 11 of 15
Highlighted
Tutor
As you suggest, I will try switching off the other two RBS's and test.  Then I will swap RBS's and re-test.
Many thanks for your help and advice, as this is a real weird scenario that I am experiencing!
Message 12 of 15
Highlighted
Guru
Ya this is kind of odd and seems to be with your setup or hardware. Smiley Frustrated
Message 13 of 15
Highlighted
Tutor
Well to my surprise, no duplicate IP address alerts overnight and that's never happened before.
All I did last thing was change the ethernet port on the Satellite associated with the duplicate IP address issue, from port 4 (next to PSU input), to port 1 and reboot satellite.
Now I've rebooted the satellite many times before without any change in behaviour, so I can only assume that the port change has resolved the issue, or possibly a combination of both.
I intend to leave it in this configuration for a couple of days, plus I have now connected a laptop via Satellite port 2, which is running WireShark with packets capture filters set for all MAC  (10xx.. & 12xx...) addresses associated with that Satellite.
If everything still works, then I'll swap back to port 4 to see if the issue reappears, whilst again running WireShark.  If it fails, I'll create a ticket with Netgear Support and ship all my diagnostics to them.
I cannot see why any of the Ethernet ports on the satellite should act in this way or differently to each other!
Once again, big shout out to FURRYe38 for your assistance!
Message 14 of 15
Highlighted
Guru
Interesting. Will be interested to know if this re-appears when you move the port back.
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 191 views
  • 2 kudos
  • 2 in conversation
Announcements
