Orbi WiFi 7 RBE973
Reply
Redundant internet connection possible?
buckaroob88
Initiate
I'm thinking of moving to an Orbi mesh system, but I was wondering if it is possible to configure a redundant internet connection, e.g. have cable modem as primary connection, but use cell or satellite if the primary goes down?  I didn't see anything in the manual, but might it be possible to kluge it with the aggregate connection?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Guru
Re: Redundant internet connection possible?
Orbi AX doesn't support fail over. You can try with LAG enabled and see. I haven't tried this.
Message 2 of 5
Guru
You able to try this out?
Message 3 of 5
buckaroob88
Initiate
No, I wound up keeping my Asus router (which can do this) and just used the Orbi mesh in access point mode.  I was afraid to set it up that way because I thought the AP mode would allow guest wifi traffic in the LAN between the AP and router, but I found out the guest wifi prevents access to the LAN and routes traffic directly out the router which was an acceptable solution.
Message 4 of 5
Guru
Kewl. Enjoy. Mark your thread as solved so others will know.
Smiley Wink
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 803 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
