Orbi WiFi 7 RBE973
Reply
Ring Doorbell Pro shows connected via a wired connection?
dtay
Luminary
I noticed in the Netgear Orbi app as well as via the GUI interface via the web browser, it's reporting that my Ring Doorbell Pro is connected to my Orbi RBK853 as a "wired" connection, when in reality, it's actually via wireless.
Anybody here using a Ring Doorbell Pro with an Orbi AX and seeing the same?
Bug? 🙂
Message 1 of 6
Accepted Solutions
dtay
Luminary
Re: Ring Doorbell Pro shows connected via a wired connection?
@FURRYe38 wrote:
Is your RBS ethernet connected to the RBR? If it is and the door bell is connected to the RBS, it will report a wired connection instead of a wireless.
Firmware is V3.2.15.25_1.3.15.
The satellites are connected via Ethernet wired backhaul.
Message 5 of 6
All Replies
Guru
is the doorbell connected to a satellite? Mine shows my devices connected to the satellites as wired. but if you log into the satellite, it shows wireless on its connected devices page.
Message 2 of 6
dtay
Luminary
I believe it was connected to a satellite when it was erroneously identiied as connected via wired.  Right now, it's showing as connected back to the main router (had to reboot the satellites last night to rearrange the power cables) and it is identified correctly as a wireless connection.  Interestingly, I also have a Ring Indoor Cam that is connected to a satellite and the Orbi is identifying it correctly as connected via wireless.
Message 3 of 6
Guru
Message 4 of 6
dtay
Luminary
Message 5 of 6
Guru
Not a bug. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2249 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
