- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Strange internet behaviour
- Mark as New
- Bookmark
- Subscribe
- Permalink
Am using Orbi AX 3 pod system for a couple of weeks now. I have noticed that once a day I loose the internet connection. I have noticed this on my iPad (WiFi) and on my PC (ethernet wired to the main Orbi router). I have to reboot to get the internet back.
Is this some sort of timeout issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Strange internet behaviour
What model Orbi do you have? RBK###?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR 353
v4.3.4.8_1.9.53
Virgin media Hub 3 (359mbps)
40ft or so between RBR and RBSx2
I have the PC linked to the RBR via ethernet (distance og 1.5m
Nothing else causes issues except internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd have your ISP check everything out up to the modem.
Is the RBR in router or AP mode?
The ISP modem has a router built in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:I'd have your ISP check everything out up to the modem.
Couple of options,
RBR is not in AP Mode - straight Router mode. VM Modem/Router IS in Modem mode, double NAT is not the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
is the behavior seen with the modem in router mode and the RBR in AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has the behavior been seen with the modem in router mode and the RBR in AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No. Not yet. I have not had any "lockups" for 2 days now, so waiting to see if it happens again.
