Orbi WiFi 7 RBE973
Reply
TWO ISSUES FOR ORBI RBK852
fangruoyuan
Guide
Re: TWO ISSUES FOR ORBI RBK852
1. Huawei MA5671 Fiber Modem- Ubnt ER4
2. I can't do that due to limited space.
Message 26 of 28
fangruoyuan
Guide
I think I noticed an obvious issue during the setup process. You could see open netgear-guest wifi sometimes. Even the guest wifi is off in the settings. It will disappear after orbi reboot. I think this isssue is related to the unsecured 5g satellite wifi ( probably same bug code in the system)
Message 27 of 28
Guru
Sounds like it might be something with you configuration as well.
Something I haven't seen however I have Cable and DHCP for ISP services.
I know with recent FW that AP mode seems to have proablems with RBS being wire connected. Today I tested both wireless and wired LAN cable direct with out any swithces and the RBS connected correctly. IF there is a switch in between the RBR and RBS, the RBS doesn't report correcty in the UI. Thought it seems to be working as I get a BLUE LED.
So if you setuo the RBR correcty first, the add the RBS later, the RBS is correctly connected and is secure?
Message 28 of 28
Top Contributors
Discussion stats
  • 27 replies
  • 3618 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
