- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Temporarily disable 5 Ghz for Weather Station
- Mark as New
- Bookmark
- Subscribe
- Permalink
AX4200 RBK752 Orbi Mesh
Please HOW TO for Dummies
How do I Temporarily disable 5 Ghz on my Orbi Mesh AX4200-RBK752 for Ambien Weather Station WS2902A
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Temporarily disable 5 Ghz for Weather Station
Unfortunately, there is no option to do this. The only thing that you can do is reduce the power level of the radios.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I reduce the power levels?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can actually just disable the wireless ssid broadcast for the 5ghz. It doesn't shut down the 5ghz but makes it more like a phone and the weather station will connect to the 2.4ghz.
Advanced---->Advanced setup------>uncheck the enable ssid braodcast for the 5ghz.
You also need to make sure the phone that you use for setup is on the 2.4ghz during the setup process. You might have to disconnect reconnect to get it to associate with the 2.4ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where do I find this?
"Advanced---->Advanced setup------>uncheck the enable ssid braodcast for the 5gh"
- Mark as New
- Bookmark
- Subscribe
- Permalink
by logging into the router through the browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
fyi, this feature isn't available on Orbi AX....We have asked for it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya, something I wish they would implement. Helpful for IoT users.
