Rich-Wales
Feb 14, 2021Follower
Voda router THG3000 to Orbi AX4200 or AX6000
Hi All,
I have seen a post that shows someone upgrading to Orbi from a Voda router.
My question is
1. Did it make a substantial positive difference in speed and wifi connectivity
2. Has anyone doen this for the wifi 6 option.
Much appreciated for your comments.
Richard.
1 Reply
Something to ask your ISP about if Orbi can replace there equipment. Some ISPs required use of there equipement.
Wifi 6 differs from WiFi 5 since it enables faster connection rates between wifi devices. So ensure that you can take advantage of these features if you choose to get into Orbi AX systems.
Things to consider for ISP modems:
Modem Combo Units: https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
If your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
