Orbi WiFi 7 RBE973
Reply
pre sales advice Orbi RBK 753
bobbinman
Hi I am thinking of upgrading my wifi ro WIFI 6. I was looking at the Orbi RBK753 I live in the UK. My ISP is Plusnet and I am on FTTC connection. My current router/modem/wifi is a Billion BiPAK8800AXL
I was looking at with help getting the Billion put into bridge mode and the connect the Orbi to that. Will this work? I was looking at the 3 pack and the 2 satalites would be connected via ethernet at varoius points arounf my property.
Thanks Chris
Message 1 of 10
Guru
Re: pre sales advice Orbi RBK 753
For modmes with built in routers...This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Message 2 of 10
bobbinman
Thanks for the reply, silly question time. Can I just plug in the orbi RBK753 router straight into my socket and configuer it with my isp details? there fore not haveing the oild billion router on the system at all?
Thanks again for your time.
Message 3 of 10
Guru
Possible however thats something to ask your ISP about to see what there requirements are. If thats something they support then the RBR should work in it's place. Contact the ISP first and get this information.
Message 4 of 10
bobbinman
They did say that as long the router was Fiber enabled, FTTP or FTTC then it should be ok. Cant find this info on the netgear site though. Thanks Chris
Message 5 of 10
Guru
Ya, thats not something Orbi systems support. So you'll need to use there Modem/ONT as the interface to there services and connect the RBR to the modem/ONT. RBK systems don't have built in modems/ONT. Only the CBR40 and CBR750 have built in cable modems and these work only on cable ISPs, not Fiber/FTTC.
Message 6 of 10
bobbinman
Ok thanks, any particular model you would recomend to work well with the RBK753
Message 7 of 10
Guru
What model are you referring too? A router or a modem?
Message 8 of 10
bobbinman
I will try your first suggestions in setting my existing router into bridge mode. Thanks so much for your help.
Message 9 of 10
Guru
Smiley Wink
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 880 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
