Reply
Wired router
Stevey
Follower
Wired router
Hi. I was looking for a wired router... does Netgear not make one?
I wanted to have a router connected to a switch that then feeds to wifi access points throughout my house, but can't seem to find a good router without wifi?
unless they have routers built into switches? I'm looking for something under $300
Thanks
edit; sorry this is in the wrong board but I don't know how to change it.
Message 1 of 2
Guru
Re: Wired router
You can buy a regular router and just disable the wifi on it if you want to stay in the consumer setup of routers.
Or you can look at something like Ubiquiti edgerouter line.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 573 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
