- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AX1800 weak 5Ghz signal
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model: SXK30B3 / AX1800
(https://www.netgear.com/business/wifi/mesh/sxk30b3/)
Hardware Version SXR30
Firmware Version V4.0.1.100
Wireless settings:
Region North America
2.4G Channel Auto ( 1 )
2.4G Mode Up to 574Mb/s
5G Channel 149+153+157(P)+161
5G Mode
When I'm anywhere in my house, including standing right in front of the base station, my 2.5Ghz signal strength is excellent and my 5Ghz signal strength is about 2/5 bars. Speed on 5Ghz suffers accordingly.
Thoughts?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX1800 weak 5Ghz signal
what speeds are you getting?
What device are you testing on?
Have you tried other devices?
Or tried a wifi scanner?
Have you checked the router vs satellites strength on a scanner?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This could indicate the mobile does not connect to the nearest 5 GHz radio (or has a problem with the 5 GHz radio), the router 5 GHz might be inactive why ever, the backhaul might operate on the 2.4 GHz band, ... Very difficult to guess.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:what speeds are you getting?
To reiterate, I'm talking about the base station router, no satellites.
The signal strength on 5GHz (ie number of bars) is about 50% on a Macbook, Android phone, iPhone and Roku, all of them within a few feet of the router. This is true for each device when no other devices are on the 5GHz band.
Speed test on the Macbook for 2.4GHz is ~240Mbps download. Same test, same device is ~67Mbps on 5GHz. No other devices are on the 5GHz band during this test.
I have not tried a scanner -- what would I be looking for there?
cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
huh, never even gotten close to 240mbps out of 2.4ghz.
I've seen it done in lab conditions but never in real world conditions.
Both my RAX200/RAXE500 peak around 120mbps in 2.4ghz. And that's peak. Usually its 50-100mbps on average.
curious if maybe you don't have that reversed?
what modem/gateway are you connected to?
did you try a factory reset and testing with the default configuration? (not loading a backup or changing from default settings on the restore)
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans wrote:huh, never even gotten close to 240mbps out of 2.4ghz.
Definitely not reversed. I used this speed test. I'm connected (hard wired) to a Spectrum-provided cable modem. It's a relatively old and barebones modem, but it's obviously the same modem on both WiFi bands. My previous WiFi router (Asus non mesh) didn't have this issue when connected to the same modem.
I haven't tried a factory reset; I guess I was hoping for a theory or something that would make it worth the inconvenience. But, yeah, that makes sense to try next.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, this is weird -- both bands are reporting 5GHz in the "channel" info on my macbook. Different BSSIDs. (having trouble posting screenshots...)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not that weird, of course each 5 GHz radio does have a different mac address (==dedicated BSSID each). And considering the system does also use of either the 5 GHz or the 2.4 GHz radio for the wireless backhaul, at least two of not all BSSIDs (while a different BSSID are used for the backhaul and the mesh discovery) must be visible near to each system, beeing the root or the satellites. As suspected earlier, we're at the point that we know your client does connect to different devices of the mesh system.
If you want to troubeshoot, you need to know the MAC blocks assigned on each Orbi Pro device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@schumaku wrote:
@mistercoffee wrote:Ok, this is weird -- both bands are reporting 5GHz in the "channel" info on my macbook. Different BSSIDs.
Well, again, I don't have satellites connected. Normally I do, but not while troubleshooting and not when I took those screenshots. In any case, I'll do a factory reset and see where I'm at.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. did the factory reset help?
2. in one photo its showing at 40hz wide and the other 80hz. there isn't a user changeable option I could find on that device to change from 40-80hz. so. a bit curious.
3. have you tried a different wifi scanner like winfi or inssider? Something that shows all the devices broadcasting and their channel/width/mac?
