Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
Both satellites connecting to the router
hvzhvz
Follower
Hello,
I have the Orbi Pro Router with two satellites.
I have a problem with both my satellites connecting to the router. I want my second satellite to connect to the first satellite (which is much closer than the router). Is there a way to force this?
Message 1 of 3
Accepted Solutions
Dd852
Luminary
Re: Both satellites connecting to the router
You need to have daisy chain enabled, of course... check to make sure it is! (advanced tab>advanced setup> wireless settings). Assuming it is, the satellites will attach to either the router or another satellite depending on which signal is stronger. I have had the experience of satellite 2 attaching to the router instead of the strong satellite 1 after a system restart (like upgrading the firmware) because of a timing issue - (in other words satelite 1 wasn't totally ready when satellite 2 was searching for a signal). That was easily fixed by simply unplugging and replugging satellite 2 for a simple restart once staellite 1 was totally up and running.
Message 2 of 3
All Replies
Dd852
Luminary
Message 2 of 3
Guru
Be sure to visit the Orbi Pro forum next time:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
Smiley Wink
@hvzhvz wrote:
Hello,
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1818 views
  • 0 kudos
  • 3 in conversation
Announcements
