Orbi WiFi 7 RBE973
Reply
Can my orbi physically locate its satellite
marksa
Initiate
I can't find the satellite which the router information says is connected.  Can the Orbi physically locate the satellite for me? Is there any other method of locating it or do I have to buy a new one?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Can my orbi physically locate its satellite
I'm confused. You have a satellite connected but you can't find it?
Does it say if its connected wired/wireless?
You could always try using a wireless scanner and walk around and test locations. The signal strengths will at least give you a general idea.
Message 2 of 4
marksa
Initiate
Thanks. Yes, it shows as connected wirelessly but I can’t find it.
Message 3 of 4
Guru
I would try using either a laptops or a phone and download a decent wireless scanner.
You can use the rssi strength to get to its general vicinity. then it should just be a matter of checking outlets or if there's POE ports.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 637 views
  • 1 kudo
  • 2 in conversation
Announcements
