Orbi WiFi 7 RBE973
Reply
Compatibility of SXS30 and SXK80
patricktong
Hi, all, can I connect SXS30 as satellite to the SXS80 as extension of my setup SXK80 network? Thanks.
Message 1 of 3
Re: Compatibility of SXS30 and SXK80
@patricktong wrote:
Hi, all, can I connect SXS30 as satellite to the SXS80 as extension of my setup SXK80 network? .
If you mean the SXR80 router, it looks like it:
Which Orbi Pro routers and satellites are compatible? | Answer | NETGEAR Support
For better advice, try the appropriate section:
Orbi Pro - WiFi for Small Business - NETGEAR Communities
Message 2 of 3
BruceGuo
NETGEAR Expert
Yes. They are compatible.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 463 views
  • 1 kudo
  • 3 in conversation
Announcements
