Orbi WiFi 7 RBE973
Reply
Does router unit SXR80 have wifi???
cmj01
Tutor
Hi all,
just got my system setup (1 router and 2 satellites) and looking at topology, all of my wifi devices seem to be connected to the satelittes and none to the router.
Given the layout of my house, I was expectecting the router to handle one half of the wifi coverage. But nothing seems to be connected directly to it.
Any ideas?
It's running in router mode - but I assumed it could do that and be a wifi access point at the same time.
Many thanks,
Mike
Message 1 of 2
Guru
Re: Does router unit SXR80 have wifi???
It does.
If you just set it up, you can try giving it a couple days.
or you can try shutting off the satellite and seeing if any connect to the router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 438 views
  • 0 kudos
  • 2 in conversation
Announcements
