Orbi WiFi 7 RBE973
Reply
FW 2.6.0.108 Deletes Address Reservations on Reboot
BooJangles
Apprentice
Performed update and lost all existing IP address reservations. Set them back up manually and will work until you perform a reboot and they are all lost again.
Model: SRK60B06|Orbi Pro Tri-Band Business WiFi System
Message 1 of 10
schumaku
Guru
Re: FW 2.6.0.108 Deletes Address Reservations on Reboot
@RaghuHR please...
Message 2 of 10
RaghuHR
NETGEAR Expert
Hi @BooJangles
 Are you managing your Orbi Pro devices via Insight? Address reservation is supported from Insight so you can use Insight to configure address reservation.
Thanks,
Raghu
Message 3 of 10
BooJangles
Apprentice
Whether I use Insight or Browser when local the reservations delete after a reboot.
Message 4 of 10
RaghuHR
NETGEAR Expert
Thanks @BooJangles  for confirming. We are working on a fix for your issue. Will update you ETA as soon as we know.
Raghu
Message 5 of 10
BooJangles
Apprentice
Please test the fix staying intact after a config restore. I have confirmed currently the reservations will show briefly after restore but then disappear once the system is fully up.
I made a backup with all the reservations so I hopefully don’t have to recreate them all manually.
Thanks
Message 6 of 10
BooJangles
Apprentice
@RaghuHR
I think this has already been mentioned in other threads but the client list randomly goes to zero on Insight mgr and the Satellite list randomly shows satellites offline (they are online).
Message 7 of 10
BooJangles
Apprentice
@RaghuHR
Is there any update on a fix for this?
Thanks
Message 8 of 10
JohnD333
Apprentice
Ditto for OrbiPRO Wifi6 (SXR80 SXS80)
I believe that reservations worked properly (were kept on reboot) until the firmware update prior to 3.2.1.102, but not certain.
With Wifi6, restoration from backup reserved IP’s are not restored - there is an empty reservation list.
Does not matter if the IP reservation is made via Insight App, Incite portal on PC, or direct on browser web interface ____._____._____.1.
Hope Netgear is working on this too.
Message 9 of 10
RaghuHR
NETGEAR Expert
Hi all,
We are workiing on this issue. Will keep you updated.
Thanks,
Raghu
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2414 views
  • 3 kudos
  • 4 in conversation
Announcements
