Orbi WiFi 7 RBE973
Reply
Factory Reset fail
JDF7
Tutor
Factory Reset fail
Hi Orbi Community,
I factory reset my router try to get rid of my old SSID but after two resets I still see them being broadcasted in my known networks. (still connectable) I used to video tutorial provided on Orbi’s Support website but to no avail, they are still there.
Message 1 of 14
JDF7
Tutor
Message 2 of 14
Guru
Re: Factory Reset fail
Does using the ERASE button on the routers web page help at all?
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
What model Orbi system do you have? I see you tagged a SXS80 series...
Message 3 of 14
schumaku
Guru
In case your ORBI SXR80 is enabled for using Netgear Insight it will (in my understanding) fetch the config again even after a factory reset. You might have to go the Insight App or Insight Web portal for configuring and changing the SSID as per your new requirements.
Not sure fellow @FURRYe38 has spotted there are (for reasons) no Orbi Pro systems listed on the KB article referenced. Feels like a lack of any practical experience operating Orbi Pro or any other Netgear Insight managed devices.
FMI: How do I reset an Insight Managed Switch or Wireless Access Point to factory default settings in Ins...  The same applies to all Netgear Insight managed devices, including the Orbi Pro systems.
Message 4 of 14
Guru
did you factory reset and/or re-sync the satellites?
I've noticed that if I only reset the router and don't sync the satellites, the satellites will retain the same ssid until that has been done
Message 5 of 14
Guru
One can find the ERASE button on most if not all NH routers, home and business:
@JDF7 wrote:
Hi Orbi Community,
Message 6 of 14
schumaku
Guru
SXS80 are pure satellites, and cant be operated without a router resp.  main unit like  SXR80. This is the unit controlling everything.
Message 7 of 14
Guru
The ERASE button sends a FR to all SXS and the SXR.
Message 8 of 14
JDF7
Tutor
I have the Orbi Pro Wifi 6 SXR80 router and satellite. I can't login into the web control page right now so I used the hardware reset.
Message 9 of 14
JDF7
Tutor
Yes i have tried re-syncing the satellite but it fails (doesn't show in the Orbi Insight app)
Message 10 of 14
JDF7
Tutor
Sorry for the confusion; i have the SXR80 and SXS80
Message 11 of 14
Guru
Did you reset both SXR and SXS?
If you ethernet connect the SXS to the back of the SXR, does the SXS get an IP address from the SXR?
Message 12 of 14
JDF7
Tutor
Thank you everyone for all your responses and help. I have the problem solved now. Please everyone have a good day!
Message 13 of 14
Guru
Please let us know how you got it solved and what worked for you. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2103 views
  • 1 kudo
  • 4 in conversation
Announcements
