- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LAN Settings SXR80 Orbi Pro
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi -
I have one SXR80 and 3 SXS80 Orbi Pro devices, and I am trying to set them up.
I have upgraded to the latest firmware on all devices, and seem to have the wireless part of the network working. I have assigned all IOT devices to WIFI 3 using the IOT VLAN.
However, I cannot seem to get the wired Ethernet ports to work on the router. I have three ethernet cables plugged into ports 2, 3, and 4 on the router (SXR80), but I cannot seem to get any internet to them. Ethernet port 1 is used for the WAN connection.
I have ethernet cables plugged into the port 1 on two of the satellites
On the LAN setup page (Advanced/Setup/LAN setup), there is NO drop-down menu (for LAN 2 and LAN 3) in the VLAN profile field, that comes up for me to change the VLANs for those LAN numbers. If I try to disable a LAN number is tells me I cannot do that because the LAN is in use.
What am I missing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LAN Settings SXR80 Orbi Pro
When I have it right, the VLAN Profiles must first be defined for the LAN (LAN2 ... LAN5) before it can be applied to a port.
FMI: Orbi Pro WiFi 6 AX6000 Tri-band WiFi System (SXK80) User Manual - Add a new VLAN profile for a LAN, p.130 ff.
