Reply
Local Login if Managing Orbi in Insight?
If I register my Orbi Pro with Insight, it changes the credentials (and settings!) locally on the router.  How do you login to the local admin screen, as none of the credentials I have appeared to work?
Message 1 of 3
Accepted Solutions
JeraldM
NETGEAR Employee Retired
Re: Local Login if Managing Orbi in Insight?
Hi @TheGrumpyGent,
It should be the Device Admin Password which is located on Locations > Location Configuration.
For your reference, kindly check this KB article.
JeraldM
NETGEAR Community Team
Message 2 of 3
All Replies
JeraldM
Hi @TheGrumpyGent,
JeraldM
Message 2 of 3
Thank you!  Not sure how I missed that (but I did!)
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 824 views
  • 1 kudo
  • 2 in conversation
Announcements
