Reply
NAT loopback _not working_ on SXS80 Satellite.
yazun
Hello,
Contrary to some information from this forum we cannot get loopback NAT working on SXS80.
It does work while connected to the main router (SXR80) but it is ridiculous one has to be connected to a speific point of the mesh system to get such basic functionality working.
Has anynody has any hints how to enable this for the sattelite?
We can get it working for few seconds by changing kernel params, but the satellite reboots then after few seconds as a security measure (sic!).
Hope soembody can help, support has ignored the question so far.
on satellite:
cat /proc/sys/net/bridge/bridge-nf-call-iptables
1
root@SXS80:~# sysctl -p
kernel.panic = 3
net.ipv4.conf.default.arp_ignore = 1
net.ipv4.conf.all.arp_ignore = 1
net.ipv4.ip_forward = 1
net.ipv4.ip_option_rr_ssrr_lsrr_pass_through = 1
net.ipv4.ipfrag_overlap_drop = 1
net.ipv4.icmp_echo_ignore_broadcasts = 1
net.ipv4.icmp_ignore_bogus_error_responses = 1
net.ipv4.igmp_max_memberships = 100
net.ipv4.tcp_ecn = 0
net.ipv4.tcp_fin_timeout = 30
net.ipv4.tcp_keepalive_time = 120
net.ipv4.tcp_syncookies = 1
net.ipv4.tcp_timestamps = 1
net.ipv4.tcp_sack = 1
net.ipv4.tcp_dsack = 1
net.dni.dod_skip_control_packet = 1
net.ipv6.conf.default.forwarding = 1
net.ipv6.conf.all.forwarding = 1
net.netfilter.nf_conntrack_acct = 1
net.netfilter.nf_conntrack_checksum = 0
net.netfilter.nf_conntrack_max = 65536
net.netfilter.nf_conntrack_tcp_timeout_established = 7440
net.netfilter.nf_conntrack_tcp_timeout_syn_sent = 60
net.netfilter.nf_conntrack_tcp_timeout_time_wait = 60
net.netfilter.nf_conntrack_udp_timeout = 300
net.netfilter.nf_conntrack_udp_timeout_stream = 300
net.netfilter.nf_conntrack_icmp_timeout = 60
net.bridge.bridge-nf-call-arptables = 0
net.bridge.bridge-nf-call-ip6tables = 0
net.bridge.bridge-nf-call-iptables = 0
vm.min_free_kbytes = 12288
config set reset_satelliteconfigs_forced=0
config commit
# NAT loopback works for few seconds then reboots after
echo 0 > /proc/sys/net/bridge/bridge-nf-call-iptables
would appreciate any hints.
 think it's not serious to have such a problem with any hardware at this price point.
Message 1 of 12
yazun
Re: NAT loopback _not working_ on SXS80 Satellite.
For the record, statement from the thread below is only partially true - it does not apply to the satellite!
.Does-OrbiPro-Wifi-6-SXK80-support-nat-loopback/m-p/1971577#M2345
Message 2 of 12
RaghuHR
NETGEAR Expert
Hi @yazun
We have the beta firmware for this issue and it is under test. Would you be interested in trying it out? We can share the firmware in next week.
Thanks,
Raghu
Message 3 of 12
yazun
Yes, certainly!
Thank you
Message 4 of 12
yazun
Hello @RaghuHR
Any news on this?
Thanks
Chris
Message 5 of 12
RaghuHR
NETGEAR Expert
Hi @yazun
Good day!
 Thank you for your patience. We should be able to provide the new beta FW in the next week.
Raghu.
Message 6 of 12
RaghuHR
NETGEAR Expert
Hi @yazun
We have completed our testing. Our Tech support will reach you on delivering the beta FW. Thanks again for your support and patience.
Raghu.
Message 7 of 12
yazun
Thank you Raghu,
Waiting fo the FW to try.
Regards
Message 8 of 12
ynghill
Tutor
Hello
i have the same problem with NAT loopback on local net i can not use my internet adress.
my fw= 3.3.0.122 the same on satellites 3pc.
Is it possebility to get the beta fix to.
Message 9 of 12
ynghill
Tutor
I find more exact my problem: if connect to wifi NAT works on lan not.
My satellite have not so strong signal so i connect with lan and then NAT stop work.
Can i miss som settings or is it fw problem?
Message 10 of 12
yazun
No solution so far.
Netgear promised fw fix for this year, but we shall see...
Message 11 of 12
DaneA
NETGEAR Employee Retired
 @yazun / @ynghill,
SXR80/SXS80 Firmware v4.0.0.118 has been recently released.  This fixes the NAT loopback issue if clients connect to the satellite.  You can download it as well as read about its new features, bug fixes and security fixes on this link
DaneA
NETGEAR Community Team
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1663 views
  • 0 kudos
  • 4 in conversation
Announcements
