Orbi WiFi 7 RBE973
Reply
NETGEAR Orbi Pro WiFi 6 AX540 SXK50B3
josueortiz
Follower
Is there a way to have a captive portal prompt with username and email using Orbi Pro WiFi 6 AX540 SXK50B3? I read the user manual under the Set up a guest WiFi network with a captive portal section, but it seems that you can only use or upload txt file with the terms and conditions and an a logo image.
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 498 views
  • 0 kudos
  • 1 in conversation
Announcements
