Orbi WiFi 7 RBE973
Reply
Netgear orbi pro srk60
LourensK
Follower
Which app can I use with the netgear orbi pro srk60?
I have downloaded the android app, but it doesn't work?
You have the insight app and the normal app (android)
Which for which system?
Message 1 of 2
schumaku
Guru
Re: Netgear orbi pro srk60
The Orbi App is for the consumer Orbi systems.
The Insight App can be used - with a different function set than the above - on the Orbi Pro and Orbi Pro WiFi 6 system.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 567 views
  • 0 kudos
  • 2 in conversation
Announcements
