- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI PRO SRR60 Satellites dropping connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
My routers firmware is at V2.6.0.108 connected the the Verizon Fios Network
Verizon Fios Modem\router connected into the ORBI SRR60 hard wired
I have noticed that i have been dropping connections between the router and the Satelites very often.
I am on channel 1 for 2.4 ghz and channel 48 for 5ghz
How can i make sure that my wireless configuration are optimized
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI PRO SRR60 Satellites dropping connection
Welcome to the community?
Just to verify, are both SRR60 and SRS60 on firmware v2.6.0.108?
How far is the SRS60 from the SRR60?
Kindly try to place the SRS60 and the SRR60 in the same room. Does same problem occur?
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
SRR60 is on the same Floor as one Satellite SRS60
The other is in the basement SRS60 in my office
All have the same ver of firmware installed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your response. 🙂
Let us try this. Kindly perform a factory reset on your Orbi Pro devices then reconfigure the settings from scratch. Then, observe if the same problem will occur.
If the same problem will occur, I suggest you to open a support ticket with NETGEAR Support here at anytime for further technical assistance.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Satellite on same floor as Router is fair .
How can I increase my satellite signal?
- Mark as New
- Bookmark
- Subscribe
- Permalink
After the swap, Is the “fair signal” location still only a “fair signal” even though it has a different satellite? If so, appliances or stucco walls on main level of home may create more interference than going between floors, even if going between floors is a greater distance. Not so sure a call to tech support will help, but (1) relocating the sat on the main level to a different location may, and if not, (2) adding another satellite on the main level should.
If as a result of the swap the fair “location” became good, and good “location” became fair, indicates that the satellite itself is the issue. A trouble ticket and call to tech support is in order.
Hood luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have only had the internet drops start since the 2.6.2.200 upgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far so Good no further drops that I have noticed since upgrading to the latest firmware.
But I stil have an issue with the connection status.
I have not had the chance to swap locations of the satelites
