Orbi WiFi 7 RBE973
Reply
Orbi Pro 6 with managed 10g switch as DHCP server and as backhaul (ethernet)
pocketsand
Follower
Hi folks,
I have the Orbi Pro 6 WiFi Business and have about 6 satellites for my home (multi level with lots of square footage). I am planning to buy a 10g managed switch (either Netgear or Cisco) and I was wondering, for the backhaul, does the 10g port even have any effect on the satellites when it's using ethernet for it's backhaul?
Model: SRK60B06|Orbi Pro Tri-Band Business WiFi System
Message 1 of 3
Guru
Re: Orbi Pro 6 with managed 10g switch as DHCP server and as backhaul (ethernet)
What version do you have?
You put pro 6 which is a couple different versions.
But you also put the SRK60 which is a AC version.
I do prefer a wired backhaul and when you have more satellites, its beneficial as it takes a load off the wireless backhaul.
Message 2 of 3
schumaku
Guru
With an all- (or almost-all-) wired backhaul customers are sacrificing the dedicated wi-Fi radio reserved for the wireless backhaul.
This makes a nice set-up for now.
Mid term, I would suggest to plan ahead on how your network should look like within a year, two, or three.
Just for the Orbi Pro backhaul alone, 10G ports don't make a lot of sense. You certainly have other reasons for a 10G capable wired network, say NAS, workstations requiring a faster network, Internet access beyond of 1 Gb, ...
If the intention will be to bring the Wi-FI network from 802.11ac to 802.11ax/Wi-Fi6, access points will be 2.5G or even 5G, so requiring MultiGig capable ports, and most likely at least PoE+ (802.3at), or even PoE++ (802.3bt).
For such an all wired wireless environment, you don't need an expensive "throw-in" Mesh system kit including a dedicated wireless backhaul capability. Just for the management, this isn't required, too.
Overall, for the switches and the router - already in combination with the existing Orbi Pro 5 system - some VLAN capabilities are almost mandatory.
Let's brainstorm now.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 942 views
  • 0 kudos
  • 3 in conversation
Announcements
