Get Orbi Pro now
Orbi Pro Support
Login to discuss Orbi Pro
Reply
Highlighted
Guru
Orbi Pro (AC) v2.5.3.110 - Guest portal now supports WPA2 mode
@Leia you confused me with the recent v2.5.3.110 firmware annoucement for the Orbi Pro (AC)s.
"Guest portal now supports WPA2 mode"
Isn't this suppoed to be WiFi Enhanced Open (if certified), based on Opportunistic Wireless Encryption (OWE, RFC8110), which is typically called Enhanced Open in WPA configuration controls? This is supposed to work with both WPA2 and WPA3 where available IMHO. Disadvantage is that clients not supporting OWE will fail to connect.
Message 1 of 4
Highlighted
Community Manager
Re: Orbi Pro (AC) v2.5.3.110 - Guest portal now supports WPA2 mode
No. This is different feature. WPA2 here provides wireless encyption to protect data in guest network.
Message 2 of 4
Highlighted
Guru
Thank you @BruceGuo - This does mean we have to provide a preshared key then?
Message 3 of 4
Highlighted
Community Manager
Yes. WPA2 requires that. I know it is not the best UX but in the platform that's so far we can do for data protection.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 92 views
  • 1 kudo
  • 2 in conversation
Announcements
