Orbi WiFi 7 RBE973
Reply
Orbi Pro SRR60 as satellite
zerus
Follower
Hi,
I want to use a second SRR60 as satellite (similar to this https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Can-I-use-the-Orbi-Pro-SRR60-Route...).
My question is: Is it possible to use the SRR60 as satellite with backhaul support? Or is it possible to flash the SRS60 firmware to the SRR60 to work as real satellite?
Message 1 of 2
Guru
Re: Orbi Pro SRR60 as satellite
No. Its not.
The SRR is a router only device. It can be used in access point mode with another SRR but it won't integrate with the mesh system.
And the flashing question? You'd be better off to try on a site that allows that with the consumer RBR and not on the official forums.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 605 views
  • 0 kudos
  • 2 in conversation
Announcements
