Orbi WiFi 7 RBE973
Reply
Orbi Pro SXR80 Guest WiFi
Fa_IT
Follower
I’ve setup the Orbi Pro guest portal for VLAN5, the issue is that the guest who will connect to guest WiFi Portal can still access devices on the main network.
I’ve checked the boxed  for both client and network isolation from VLan/Bridge settings for guest wifi VLAN.
Scenario:
  • Main Network: 192.168.42.x
  • Getting IP: 192.168.1.x from Orbi Pro WiFi
  • IP from guest portal: 192.168.50.x
Now both 192.168.1.x and 192.168.50.x can access printer in 192.168.42.x
I don’t mind internal access from 192.168.1.x however Guests should not have access to main network 192.168.42.x and/or devices on it.
Message 1 of 2
Guru
Re: Orbi Pro SXR80 Guest WiFi
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 904 views
  • 0 kudos
  • 2 in conversation
Announcements
