Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
Orbi Pro missing Daisy Chain topology
Happymak
Orbi Pro missing Daisy Chain topology is missing Daisy Chain topology in V1.12.1.28 firmware.
It's illogical that a "Pro" version of a product misses one important feature of the least expensive model.
Also, several vendors state that this product creates a "wireless mesh network", but in practice satellites only connect to routers, so for now this is a false statement.
Any workaround for this?
Surely Netgear can make this right in the near future.
Model: Orbi Pro Tri-band WiFi System (SRK60) AC3000
Message 1 of 7
Accepted Solutions
Boomerang3
Apprentice
Re: Orbi Pro missing Daisy Chain topology
Try the debug page.  [ip]/debug.htm
Boomerang3
Orbi (SRR60, SRS60, SRC60) FW v2.5.3.110
Netgear Switch GS116Ev2
Netgear Cable Modem CM600
Message 2 of 7
All Replies
Boomerang3
Apprentice
Boomerang3
Message 2 of 7
Happymak
The option seems to be unavailable.
Message 3 of 7
tneorg
Hmmm, I just found that on the debug page. Anyone know why it might be there AND disabled?
Message 4 of 7
Happymak
Found a solution thanks to @Boomerang3.
First I installed the V1.12.1.38_BETA firmware (sent to me by a Netgear support representative) on my Orbi Pro router and both of the Orbi Pro Satellites.
Then, I tried enabling daisy chain feautre through the [ip]/debug.htm of one of the satellites, but the feature was disabled and locked.
The solution was to enable the daisy chain feature through the [ip]/debug.htm of the router, which allowed the change.
After this, and waiting a couple of minutes, both the satellites had the daisy chain feature enabled and a working connection between the two of my satellites.
Greetings,
Simon
Message 5 of 7
tneorg
Are Orbi Pro Beta Firmware updates recommended? Everything is running well now, and I don't want to introduce any issues. Has anyone else upadated to the .38 Beta Hotfix?
Message 6 of 7
tneorg
With the new update, the Enable Daisy Chain has appeared in the Wireless Settings.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 5671 views
  • 0 kudos
  • 3 in conversation
Announcements
