× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Orbi Webinterface nicht alle Funktionen erreichbar
Limabsl
Hallo, ich kann beim Orbi Webinterface nicht alle Funktionen anwählen. Sie erscheinen zwar, sind aber nicht anwählbar. Bsp. Internet im Basic, und im Advanced Setup Assistent, Seiten und Dienste sperren etc.
Komischerweise habe ich auch über die App keinen Zugriff auf den Orbi Router, obwohl per WLAN mit dem Orbi Netzwerk verbunden.
Vielen dank im Voraus.
LIMABSL
Message 1 of 9
Guru
Re: Orbi Webinterface nicht alle Funktionen erreichbar
Englisch Bitte
Message 2 of 9
Limabsl
Sorry...
In the Orbi Webinterface i can't choose all of the options, for example in Basic settings "Internet", in Advanced "Internet Setup", Port forwarding, parental control...
Also i can't acces via the App to the router. The App says no Orbi Network deteced, but i am connected to the orbi network.
Thks a lot in advance
LIMABSL
Message 3 of 9
Guru
Is Armor or Circle enabled on the RBR?
What browser are you using?
Message 4 of 9
Limabsl
Hello, thank you for your answer.
Firmware is V2.6.0.108
ISP is Nordnet France, Modem is Nordbox (Sagemcom) for Fiber
I don't know if Armor or Circle is enabled, i can't see it on the webinterface.
With the App no connection possible
Message 5 of 9
Guru
What model Orbi do you have?
You might want to post in the Orbi app forum for any app help and information:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Message 6 of 9
Limabsl
Orbi SRS 60 with 6 Satellites.
I have checked now Firefox, Windows and Chrome, but all the same
Message 7 of 9
Guru
Ok this is for a Orbi Pro system, please visit and post about this in the Orbi Pro forum:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
Will see if we can get this thread moved there as well.
Good Luck.
Message 8 of 9
schumaku
Guru
Reads to me like these are features intentionally not available in AP (access point) mode.
Reads familiar, several reports on the recent Orbi Pro update.
The Orbi App for the Orbi Pro is kind of on it's way out (but recently still supported) - it's suggested to use the Insight App.
Message 9 of 9
Discussion stats
  • 8 replies
  • 869 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
