Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
Question about SXR80 firmware 4.0.0.118 and known issue workaround
Architekt
Guide
One of the items in the patch notes says this:
  • When the SXR80 router is connected to multiple SXS30 and SXS80 satellites, wireless clients that connect to wireless network 3 with VLAN enabled cannot access the Internet.
    Workaround: Reload the wireless configuration or disable the VLAN feature on wireless network 3.
Just so I don't mess myself up, since I do use wireless network 3 with VLAN, what *exactly* is meant by "reload the wireless configuration" and how do I do that? Does that just simply mean use the "Backup Settings" tab BEFORE I update, then update to the latest firmware, then when everything is all done simply restore that backup? Or should I backup AFTER I update and then restore? Or is it something entirely different? Thanks!
Message 1 of 3
BruceGuo
NETGEAR Expert
Re: Question about SXR80 firmware 4.0.0.118 and known issue workaround
You just need to change setting and apply again.
Message 2 of 3
JTK
I'm having issues with this firmware update.  Many of my wireless IOT devices on the same VLAN profile shared with LAN3 are losing connection and then reconnecting at a later time.  This started occurring after the firmware update.  I've tried restoring settings from a previous backup, but this only fixes the issue for a couple of hours before returning.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 507 views
  • 0 kudos
  • 3 in conversation
Announcements
