- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SRR60 Wireless2 no internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
SRR60 with latest firmware downloaded.
Set in AP mode with static IP on LAN.
Wireless1 and Wireless2 enabled. Guest SSID disabled.
Clients can connect to Wireless1 just fine and access internet.
Clients get IP if connecting to Wireless2 but cannot get to internet unless check box for "Allow employees to see
each other and access my local network" is checked. But obviously I dont want to have that checked !
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SRR60 Wireless2 no internet
According to your description, I verified this version(2.4.0.114) and found no problems. Are you also in this version? Could you please send us the config file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
From my own experience, the system takes a while to engage. Leave it for 15-30 mins and see if it works as it should.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see the issue using your config, because LAN IP is different from DHCP server,
I restore your config, OrbiPro br0 IP is static 192.168.1.10 in AP mode, but my DHCP is 192.168.30.x,
How do you set a static IP in AP mode?
WAN and LAN settings are gray out in AP mode, I can't set it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@evan2 Static IP is set for 192.168.1.10 and DHCP server is at 192.168.1.254
If you take the option to change the setting from Router to AP mode - it lets you set the static IP address and then it grays out the option once it is set in AP mode so you cannot change it unless you do a factory reset.
I have opened a cae with netgear support and they were able to replicate the issue so am awaiting their feedback on what to do next.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
