Orbi WiFi 7 RBE973
Reply
SRS60 firmware update issue
jcbick
Hello all.
I'm not sure how I screwed up, but i can't seem to get all of my satellites to update to the latest firmware.  I've attached a pdf with screen shots.  How can I get the router to recognize that it says the satellites are connected but not connected enough (apparently) to get firmware updated?
Message 1 of 3
Accepted Solutions
jcbick
Re: SRS60 firmware update issue
Trying to login remotely via IP address did not work.  Wound up connecting directly to each problem satellite via cable and eventually getting the local page to show and allow the firmware upgrade.  Now that they are all the same version, everything is copasetic.
Message 3 of 3
All Replies
quagmire1
Luminary
You should be able to login to each satellite directly by its IP address. Once in, there is a "Firmware Update" option.
Message 2 of 3
jcbick
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 940 views
  • 2 kudos
  • 2 in conversation
Announcements
