Orbi WiFi 7 RBE973
Reply
SRX50 problem
limesin
SRX50 problem
Hi
The router is down after the firmware update attempt. The DC led is black. The power supply has been checked and is ok.
Message 1 of 12
Guru
Re: SRX50 problem
What happens after a 15 seconds press then release of the reset button in back?
Message 2 of 12
limesin
Re: SRX50 problem
Nothing. Still black.
Message 3 of 12
schumaku
Guru
Re: SRX50 problem
Correct 12V, 3.5A DC output power supply plugged?
No Power LED is unlikely coming from a failed firmware update. Could well be a hardware failure. Head to https://my.netgear.com/ - click your router (based on the serial number) and follow the (Request Hardware Support) process.
Message 4 of 12
Guru
Re: SRX50 problem
Try a 30-30-30 reset.
Message 5 of 12
schumaku
Guru
Re: SRX50 problem
Have also an SXS50 at hand? Plug it to the same power supply as in use (with power LED black) and check if the satellite does power up on the same power supply. Try the SXS50 power supply for the SXR50, too. This should make it clear which device is broken.
Message 6 of 12
limesin
Re: SRX50 problem
Nothing. Still dead.
Message 7 of 12
limesin
Re: SRX50 problem
The power supply is ok. Checked few times. On SXS50 as well.
Message 8 of 12
limesin
Re: SRX50 problem
When I send the hardware support request I got the following message: somethingWentWrong'
Message 9 of 12
limesin
Re: SRX50 problem
I was able to create the hardware support request finally.
However any suggestion how to resolve it is very welcome.
Message 10 of 12
Guru
Re: SRX50 problem
Any progress on this?
Message 11 of 12
limesin
Re: SRX50 problem
Yes.
O got the new router. Everything is ok. THX!
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1488 views
  • 0 kudos
  • 3 in conversation
Announcements
