Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Reply
SSID
arizzo4521
SSID
my orbi is working fine, i have a wifi analyzer, it shows my ssid with what looks like different addresses, the different addresses have different signal strengths. my devices only show one ssid option, what are these different addresses and how do i know my devices are using the one with the best signal
Message 1 of 5
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: SSID
@arizzo4521,
I just want to follow-up on this.  Let us know if have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Message 4 of 5
All Replies
wase4711
Luminary
Re: SSID
the 2 "addresses" are probably 2.4ghz band and the 5ghz band..
Message 2 of 5
DaneA
Re: SSID
Hi @arizzo4521,
Welcome to the community! 🙂
One of the advanced feature of the Orbi Pro is band steering wherein it intelligently selects the best Wi-Fi band for each dual-band wireless device to optimize connection based on the speed and performance capabilities of the wireless device.  As reference, kindly read the article below:
What advanced features does my Orbi WiFi System support?
DaneA
Message 3 of 5
DaneA
Re: SSID
@arizzo4521,
DaneA
Message 4 of 5
arizzo4521
Re: SSID
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2234 views
  • 0 kudos
  • 3 in conversation
Announcements
